Trick Laser heat spreader
WZ9V
Post by WZ9V »
When using the Trick Laser heat spreader with the Onyx heat bed should it be double sided taped to the PCB or is clamping it down with the glass sufficient?
ccavanaugh
Re: Trick Laser heat spreader
Post by ccavanaugh »
Just clamp it down with the glass. Make sure you keep the film size against the PCB to prevent shorts.
WZ9V
Post by WZ9V »
Thanks. I was just checking their website for that. Of course I had it upside down and need to flip it over. Good thing I like to confirm before applying power.
