Trick Laser heat spreader
When using the Trick Laser heat spreader with the Onyx heat bed should it be double sided taped to the PCB or is clamping it down with the glass sufficient?
Re: Trick Laser heat spreader
Just clamp it down with the glass. Make sure you keep the film size against the PCB to prevent shorts.
Thanks. I was just checking their website for that. Of course I had it upside down and need to flip it over. Good thing I like to confirm before applying power.
