Rostock max v1
mcdarren23
Re: Rostock max v1
Post by mcdarren23 »
good afternoon. having a few issues again lol im sure this will go on for a while. lcd works so thats a plus. arms still wont manu move. i uploaded the eeprom clear file. didnt change anything thanks
Nylocke
Re: Rostock max v1
Post by Nylocke »
Your symptoms are quite interesting. I'm not sure what is going on. I just uploaded the firmware I built onto a spare RAMPS board I had and plugged in my LCD. The LCD works, I don't have any motor drivers to test if the motors work, but all the EEPROM variables work fine. I noticed I accidentally switched the delta arm length and horizontal radius on the config, so I'm uploading a new version of the firmware. I also changed the EEPROM set to set 2, maybe it might properly write the EEPROM variables this time.
Repetier-Firmware-2016-04-28.zip
(432.9 KiB) Downloaded 296 times
Showing the settings I used to upload to the board, and confirming EEPROM is working.
mcdarren23
Re: Rostock max v1
hi all got somehwere this morning.
went through all the wiring and the person who build it messed it all up and did it all wrong ! (HOW SO, WHO KNOWS) so after many hours rewired it and got it all going
extruder and bed are working fine now.
so whats next ? i was trying to calibrate the arms as shown on the videos.......... seem to be hitting a brick wall again. i home all and nothing happenes. are the videos on youtube etc ok for this of is there still some mods i need to do
thanks
Re: Rostock max v1
Considering the condition of the arms when you got it, do you mind if I take a few hours to work on my "surprised" face on hearing he borked the wiring too? :)
Are you able to move the axes individually?
mcdarren23
Re: Rostock max v1
yes i can move them all on their own. althou on the log screen on rep host
it keep slisting
wait
wait
14:46:25.649 : ok 162
14:46:25.649 : T:42.59 /0 B:21.95 /0 B@:0 @:0
14:46:26.647 : wait
14:46:27.646 : wait
14:46:28.660 : wait
14:46:28.706 : N163 M105*35
14:46:28.706 : ok 163
14:46:28.706 : T:42.41 /0 B:21.95 /0 B@:0 @:0
14:46:29.705 : wait
14:46:30.703 : wait
14:46:31.717 : wait
and so on and so on lol
Nylocke
Re: Rostock max v1
Post by Nylocke »
Im betting the endstops are wired NO. Send M119 and it should tell you if they are triggered or not. If they are then some firmware changes are needed. Do the carriages move the correct direction?
mcdarren23
Re: Rostock max v1
it says end stop hit.... but the arms are still in the middle of the machine
y/x up z goes down
z up z & x up y down
x & y left x & y goes up
x & y right x & y goes down
thansk
mcdarren23
Re: Rostock max v1
y/x up z goes down
mcdarren23
Re: Rostock max v1
y/x up.................... z goes down
z up ......................z & x up y down
x & y left .....................x & y goes up
x & y right .....................x & y goes down
Nylocke
Re: Rostock max v1
Post by Nylocke »
Ok, ill upload a proper confog here shortly. The endstops are wired slightly differently.
Nylocke
Re: Rostock max v1
Post by Nylocke »
Try this out
RAMPS.zip
(454.8 KiB) Downloaded 430 times
mcdarren23
Re: Rostock max v1
Hi all. Uploaded the ramps and it worked. I went through all the set up etc. But when it came to saving the settings in rep host Ie script 1 2. 3. They arnt there. Aldo when I home the arms. They go straight to the top and keep going after hitting the end stops. Thanks
Nylocke
Re: Rostock max v1
Post by Nylocke »
If the endstop wiring is the same as the picture you posted before, the endstops are plugged into the min endstop pins instead of the max endstop pins. I set up the firmware for the max endstops, so just move all of them over one. It should be labeled min vs max.
mcdarren23
Re: Rostock max v1
hi i tried that and tried calibrating the arms etc but it still not working right. when i click the home button also where should the arms go to ?
tried the recal like the video a few times but somthing isnt right
thanks
Nylocke
Re: Rostock max v1
Post by Nylocke »
The arms should move up. Are they moving down a small amount? That means they might be wired NC, but since they were on the wrong pins it seemed like the config was wrong.
mcdarren23
Re: Rostock max v1
i think the set up in general is ok. it might just be that i am doing it wrong... or the method on youtube wont work with the firmwear/v1 early mod i have ?
when i home all be4 calib the hot end goes well away from centre.
whats the best way to set up home for all arms ?
thnaks
Nylocke
Re: Rostock max v1
Post by Nylocke »
What happens when you press *home all* in repetier? Can you video it? Im having a real hard time understanding whats going on so its difficult to help
