Will I have an issue if the cable length from the LCD to the Rambo is about 700mm long?
Thanks
Tony
LCD Cable length
LCD Cable length
Re: LCD Cable length
You'll have problems if they're any longer than the stock LCD cables. Any longer and you'll need to shield them and/or wrap them through a ferrite core.
Ok, thanks
I tried 800mm (because i was curious) and just finished a 3 hr print and all went good using an sd card too. Go figure.
