Custom start/end g-code
BenTheRighteous
Post by BenTheRighteous »
In the tooltip for the start g-code option, it says you can use values from other settings like this: [temperature]
That's all it says though, which isn't too helpful. It's not even a good example because is it extruder temperature or bed temperature? Which extruder?
Does anyone have documentation on what the full list of options is? I'm really hoping we can use xyz coordinates like KISSlicer allows. It's a stretch I'm sure, but it would be nice...
Re: Custom start/end g-code
Look at the main page of the Repetier firmware. It lists all of the GCode commands that the firmware can take.
Usually the 'stock' start/end codes are pretty close. A few, like Cura need some tweaks. (specifically the G28 X0Y0Z0 command only needs to be G28)
BenTheRighteous
Thanks Jim. I'm not quite sure what you're referring to... this perhaps?
http://www.repetier.com/documentation/r ... tallation/
This page also lists all gcodes and their functions, which I like.
http://reprap.org/wiki/G-code
What I was asking though was about the substitution feature in MatterControl specifically. So that if you put something like this in your "start g-code" box:
M104 S[temperature]
...when you slice a model, the generated gcode would become:
M104 S225
(just for example)
Just for context, what I'm looking to do is make the effector travel to a wipe pad every time it changes extruders. So I'd be hoping I could write something like this:
G1 X-130 Y20 Z[currentZ]
G1 Z6
G1 Y-130 Y-20
G1 Z[currentZ]
It's possible in KISSlicer. I don't know if it's possible in MatterControl... that's what I'm trying to figure out.
Sorry, I wasn't clear about that. I meant opening the Arduino sketch for the firmware... That front page.
To your other point, I'm not terribly familiar with MC software, so I'm probably not the best to help you there.
Repetier wrote:\section GCodes Implemented GCodes
look here for descriptions of gcodes: http://linuxcnc.org/handbook/gcode/g-code.html
and http://objects.reprap.org/wiki/Mendel_U ... pRapGCodes
Implemented Codes
- G0 -> G1
- G1 - Coordinated Movement X Y Z E
- G4 - Dwell S<seconds> or P<milliseconds>
- G20 - Units for G0/G1 are inches.
- G21 - Units for G0/G1 are mm.
- G28 - Home all axis or named axis.
- G29 S<0..2> - Z-Probe at the 3 defined probe points. S = 1 measure avg. zHeight, S = 2 store avg zHeight
- G30 - Single z-probe at current position
- G31 - Write signal of probe sensor
- G32 S<0..2> P<0..1> - Autolevel print bed. S = 1 measure zLength, S = 2 Measue and store new zLength, P = 1 iterative correction for delta
- G90 - Use absolute coordinates
- G91 - Use relative coordinates
- G92 - Set current position to cordinates given
- G131 - set extruder offset position to 0 - needed for calibration with G132
- G132 - calibrate endstop positions. Call this, after calling G131 and after centering the extruder holder.
RepRap M Codes
- M104 - Set extruder target temp
- M105 - Read current temp
- M106 - Fan on
- M107 - Fan off
- M109 - Wait for extruder current temp to reach target temp.
- M114 - Display current position
Custom M Codes
- M20 - List SD card
- M21 - Init SD card
- M22 - Release SD card
- M23 - Select SD file (M23 filename.g)
- M24 - Start/resume SD print
- M25 - Pause SD print
- M26 - Set SD position in bytes (M26 S12345)
- M27 - Report SD print status
- M28 - Start SD write (M28 filename.g)
- M29 - Stop SD write
- M30 <filename> - Delete file on sd card
- M32 <dirname> create subdirectory
- M42 P<pin number> S<value 0..255> - Change output of pin P to S. Does not work on most important pins.
- M80 - Turn on power supply
- M81 - Turn off power supply
- M82 - Set E codes absolute (default)
- M83 - Set E codes relative while in Absolute Coordinates (G90) mode
- M84 - Disable steppers until next move,
or use S<seconds> to specify an inactivity timeout, after which the steppers will be disabled. S0 to disable the timeout.
- M85 - Set inactivity shutdown timer with parameter S<seconds>. To disable set zero (default)
- M92 - Set axisStepsPerMM - same syntax as G92
- M104 S<temp> T<extruder> P1 F1 - Set temperature without wait. P1 = wait for moves to finish, F1 = beep when temp. reached first time
- M105 X0 - Get temperatures. If X0 is added, the raw analog values are also written.
- M112 - Emergency kill
- M115- Capabilities string
- M116 - Wait for all temperatures in a +/- 1 degree range
- M117 <message> - Write message in status row on lcd
- M119 - Report endstop status
- M140 S<temp> F1 - Set bed target temp, F1 makes a beep when temperature is reached the first time
- M190 - Wait for bed current temp to reach target temp.
- M201 - Set max acceleration in units/s^2 for print moves (M201 X1000 Y1000)
- M202 - Set max acceleration in units/s^2 for travel moves (M202 X1000 Y1000)
- M203 - Set temperture monitor to Sx
- M204 - Set PID parameter X => Kp Y => Ki Z => Kd S<extruder> Default is current extruder. NUM_EXTRUDER=Heated bed
- M205 - Output EEPROM settings
- M206 - Set EEPROM value
- M207 X<XY jerk> Z<Z Jerk> E<ExtruderJerk> - Changes current jerk values, but do not store them in eeprom.
- M220 S<Feedrate multiplier in percent> - Increase/decrease given feedrate
- M221 S<Extrusion flow multiplier in percent> - Increase/decrease given flow rate
- M231 S<OPS_MODE> X<Min_Distance> Y<Retract> Z<Backlash> F<ReatrctMove> - Set OPS parameter
- M232 - Read and reset max. advance values
- M233 X<AdvanceK> Y<AdvanceL> - Set temporary advance K-value to X and linear term advanceL to Y
- M251 Measure Z steps from homing stop (Delta printers). S0 - Reset, S1 - Print, S2 - Store to Z length (also EEPROM if enabled)
- M280 S<mode> - Set ditto printing mode. mode: 0 = off, 1 = on
- M300 S<Frequency> P<DurationMillis> play frequency
- M303 P<extruder/bed> S<printTemerature> X0 - Autodetect pid values. Use P<NUM_EXTRUDER> for heated bed. X0 saves result in EEPROM.
- M320 - Activate autolevel
- M321 - Deactivate autolevel
- M322 - Reset autolevel matrix
- M340 P<servoId> S<pulseInUS> : servoID = 0..3, Servos are controlled by a pulse with normally between 500 and 2500 with 1500ms in center position. 0 turns servo off.
- M350 S<mstepsAll> X<mstepsX> Y<mstepsY> Z<mstepsZ> E<mstepsE0> P<mstespE1> : Set microstepping on RAMBO board
- M400 - Wait until move buffers empty.
- M401 - Store x, y and z position.
- M402 - Go to stored position. If X, Y or Z is specified, only these coordinates are used. F changes feedrate fo rthat move.
- M500 Store settings to EEPROM
- M501 Load settings from EEPROM
- M502 Reset settings to the one in configuration.h. Does not store values in EEPROM!
- M908 P<address> S<value> : Set stepper current for digipot (RAMBO board)
samschad
Post by samschad »
Ben-
Was wondering about this as well tonight, and this is what I came up with, which works beautifully:
M104 S[temperature]
M190 S[bed_temperature]
M109 S[temperature]
G28
Got the idea from http://www.repetier.com/documentation/r ... de-editor/
Return to “MatterControl”
