Zoe's (Rostock Max V2) Enclosure
We just finished the enclosure for our Rostock Max V2. Her name is Zoe
Thanks to @JFettig for the design work it turned out well.
Re: Zoe's (Rostock Max V2) Enclosure
Looks good
Looks awesome!!
Here is a before and after picture.
[img]http://forum.seemecnc.com/download/file ... 533115eded[/img]
BenTheRighteous
Boy, JFettig's enclosure sure is popular!
That reminds me, I have to go dig up that thread to make a suggestion...
drwho, you should consider swapping out the blue LCD for a yellow one. That would look sliiiiiick next to those yellow brackets!
Did you have any difficulties printing the X.stl file? That seems to be the one file I can't get to print.
SeeMeCNC Rostock Max V2
Makerbot Replicator Gen 5
CRPerry Jr. No trouble with printing the X.stl file. What issue is it giving you?
Ny issue printing the x.stl file was the z-lift. it was set to low at default. I received recommendations to raise it to 1 mm, which did the trick!
What layer height are you using?
The majority of our pieces are printed at .4 mm height.
