V2 in Minnesota - plenty of questions.
JFettig
Re: V2 in Minnesota - plenty of questions.
Post by JFettig »
I will have to post it up when I get home :)
JFettig
Post by JFettig »
Here are the files
http://repables.com/r/436
BenTheRighteous
Post by BenTheRighteous »
Thanks! How do you attach that 3rd screw? Do you just thread it into the print itself or do you manage to get a nut in there somehow?
JFettig
Post by JFettig »
I threaded them all into the print using sheet metal screws
RegB
Post by RegB »
Koooo_wel, THANKS !!!
Gotta print me one (or several) o' them (-:
Thank you for posting the files, this look like a good fan mount!
JFettig
Post by JFettig »
Had some corners lift on kapton so I added abs juice... Wow that made it impossible to get the parts off. Mix juice thinner or skip kapton?
jdurand
Post by jdurand »
Windex (tm)
JFettig
Post by JFettig »
Tried, didn't help with removal of the parts
jram
Post by jram »
I third that! I like that design, my shroud now only seems to cool 1/2 of the material.
lightninjay
Post by lightninjay »
Hey JFettig! I just wanted to say thanks for the files! Your mount works great :)
It's helping me print my cousin a Tardis at the moment!
Your shroud is awesome!!
JFettig
Post by JFettig »
lightninjay wrote:Hey JFettig! I just wanted to say thanks for the files! Your mount works great :)
Awesome! glad they're getting put to use!
I'm building an enclosure for my printer, just 3 more prints for the top brackets then need to print up 3 or 4 parts for the latch setup. I'm running out of white ABS so the rest of the parts might have to be black.
[img]http://i.imgur.com/49ADE0K.jpg[/img]
JFettig
Post by JFettig »
Just printed the last one of the enclosure brackets, I had about a foot of white filament left at the end of that! Then I noticed that my PEEK fan wasn't running, somehow it jammed up or something, the fan shroud is completely melted but the hot end seems fine surprisingly!
Post by Mac The Knife »
It seems that bushed fans don't last long in these printers. Both my Rambo and Peek fan have been replaced with ball bearinged versions.
nitewatchman
Post by nitewatchman »
Mine also, Peek Fan about a week - Rambo Fan about a month.
bot
Post by bot »
I never even installed my rambo fan, and my first peek fan was DOA (essentially) and my second one seems to be slowly dying, but I've got an e3d on the way and a ball bearing 25mm backup for the seemecnc hot end which will be a backup to the e3d.
*not actually a robot
jram
Post by jram »
Hi JFettig. Just wanted to say thanks for making this stl available. Printed one out this morning and the fit is superb, seems to be cooling much better than my my original configuration.
