I just ordered a rostock that should arrive tomorrow. im putting together all of the parts from the list, that ill need.
I dont have time to get the item directly from mcmaster... is there any other option available for this part?
thanks
PTFE tubing from
McMaster-Carr, P/N: 5335K13
thank you
Options for PTFE tubing from McMaster-Carr, P/N: 5335K13
- redoverred
Re: Options for PTFE tubing from McMaster-Carr, P/N: 5335K1
You shouldn't need that, where did you see you needed it?dunginhawk wrote:I just ordered a rostock that should arrive tomorrow. im putting together all of the parts from the list, that ill need.
thanks
PTFE tubing from
thank you
Built one last month. All PTFE tubing used was included in the kit.
Things I had to buy:
crimp connectors for the hot end resistors/wiring
ultra copper RTV silicone
kapton tape
disappearing purple glue-stick
Things I chose to add/change:
JST plugs for the PEEK and layer fans
Astrosyn isolation mounts for the axis motors
better fan for PEEK fan (stock one was junk)
better fan for RAMBo cooling (stock one was loud)
kapton tape
found it on page 6.
http://www.geneb.org/rostock-max/Rostoc ... -Guide.pdf
thanks for the submissions guys.
as long as i can get up and running and printing/testing ill be ok.. i can always replace those parts later.
thanks again
thanks again
If you just ordered, you'd be getting a Version 2 Rostock, and I believe that is included in the hot-end kit now. You're reading the older assembly guide for the Version 1 Rostock.
But to answer the question, in the past a common insulation alternative to tiny PTFE tubing was with Kapton tape.
thank you very much... very appreciated.
