New Cheapskates Revealed!
I hacked into the SeemeCNC computers and found two images of the new cheapskates for all of you that were wondering
and to burst Gene's "secret". For your enjoyment:
Re: New Cheapskates Revealed!
I'm guessing the second picture is part of the injection mold for the cheapskate frame in the first picture.
I believe that is correct.Eric wrote:I'm guessing the second picture is part of the injection mold for the cheapskate frame in the first picture.
Yep, that's part of the injection mold.
You guys are gonna love those things.
McSlappy
These look cool! Will they be able to be retrofitted to v1 and v2's ?
Here are my espionage photos, too!
http://imgur.com/a/zmGoE
They'll work with the new style arms (with the plastic spring clips), so yes to the V2's, and yes to the newer V1's. Luckily, all of the conversion parts are available for older machines, so you can do the upgrade on any SeeMeCNC machine, you just might need a few extra bits and pieces.
After getting the pictures and seeing what you have posted I can't help but wonder if those cheapskates will come apart for repairs to the wheels.Jimustanguitar wrote:Here are my espionage photos, too!
The seam looks as though it is glued together.
I see phillips head screws in the pictures, so I'd say they come apart.
After looking again, I can now see the screws, thanks you have some sharp eyes!Eric wrote:I see phillips head screws in the pictures, so I'd say they come apart.
What are they functionally improving?
Follow My Rostock MAX V2 Build in progress.
- joecnc2006
Now have to see how to adapt the magnetic Arm Mod to those.
Joe
They have built in springs that control the pressure of the rollers, no more adjustments.edge922 wrote:What are they functionally improving?
It is 2 plastic parts and 2 screws that replace 4 nuts, 4 screws, 4 cams, 4 spacers, 2 pieces of wood, and 1 arm carriage (and that's if you don't use any washersedge922 wrote:What are they functionally improving?
Did it come with the V1 to V2 kit you received?Jimustanguitar wrote:It is 2 plastic parts and 2 screws that replace 4 nuts, 4 screws, 4 cams, 4 spacers, 2 pieces of wood, and 1 arm carriage (and that's if you don't use any washersedge922 wrote:What are they functionally improving?) I'm sure it's considerably lighter too.
they have not started shipping yet.. we are still testing and tweaking
Guanu
Guanu
Nope. I only got wooden parts. The official kit will have more, based on the list of things that I needed to finish the job.Eaglezsoar wrote: Did it come with the V1 to V2 kit you received?
The bearings in my pictures were the only ones on the planet at the time (probably in the universe). Since then, they've re-made the mold with some refinements and are (I assume) gearing up for production.
They look absolutely superb! I'm really excited to see how these are released (standalone + upgrade kit, for those of us who don't want a full upgrade kit please!).
- joecnc2006
I wonder how the Tensioners will last on the Bearings, Looks like it is just molded and relays on the plastic spring tension. I could be wrong and not seeing something.
Joe
Nope, no springs or anything, just the flex of the plastic.joecnc2006 wrote:I wonder how the Tensioners will last on the Bearings, Looks like it is just molded and relays on the plastic spring tension. I could be wrong and not seeing something.
I'll be curious to see what mileage these are good for as well.
Mind = Blown.
I saw some pics online of these things that someone took at the Midwest RepRap festival. They were not real close up views, but I could tell they were transparent and so I know this is what I saw. I was afraid to say anything because I didn't want to make anyone mad incase there were others like me who would be tempted to hold off until these came out.
I hope it is soon. Any estimates?
Thank you for sharing.
SeeMe doesn't usually make release ETAs since they hate to disappoint if something goes wrong, just wait.Brian wrote:Mind = Blown.
