I have a Rostock max v1 that is running dual extruders.
I am currently cooling the PEEK sections of the hot ends with a compressed air supply, which I turn on and off manually.
I have the machine inside a heated cabinet, and I also turn the heater unit [that heats the cabinet] on and off manually.
What I need to do is:
- configure the Fan0 port on the RamBO to produce a 12V* signal whenever either Extruder 0 or Extruder 1 is switched on - to operate a flow valve for turning the compressed air supply on and off
- configure the Fan1 port on the RamBO to produce a 12V* signal whenever the bed heater is switched on - to operate a relay for turning the cabinet heater on and off
(*Signal could be any voltage I guess, 3V, 5V, 10V, 12V... so long as it is consistent so it can operate a relay)
However, I have absolutely no idea what I'm doing when it comes to editing the firmware. What would I need to change in / add to the firmware to achieve this?
Thanks in advance. This is what happens when mechanical engineers try to play wit things that involve programming
