Not sure if this is the best place to post this, but I have a max v2. I haven't used it for a while, but I got it up and running again and everything seems fine, but the eeprom keeps resetting. I usually print from SD card, and when I went to print today (after I unplugged my computer), The extruder didn't go down to the right z height, so I knew something was wrong. Then I plugged in and connected my computer and it said "printer reset detected - initializing". Any ideas why the printer is resetting? I don't think it happens every time I shut off the printer. Maybe it has something to do with not being plugged into the computer?
Thanks
eeprom resetting
- Tincho85
Re: eeprom resetting
Did you try clearing and uploading the firmware again?
Use 0.91, it's the last stable.
Martín S.
