Proto pasta iron letter sign
Posted: Sat Aug 22, 2015 4:28 pm
by drwho
We're making a letter for our door. We just finished a test print in PLA. We'll be printing in the iron filament soon. I'll update this post with the results.
Re: Proto pasta iron letter sign
Posted: Sun Aug 23, 2015 10:11 am
by Holy1
Very nice but you are over extruding quite a bit and maybe running a little hot.
Posted: Sun Aug 23, 2015 6:45 pm
by drwho
Is the over extrusion causing the folding? Still new to PLA so pointers are greatly appreciated.
Posted: Sun Aug 23, 2015 9:45 pm
by Holy1
If you talking about the ridges on the top layer the yes, for sure. Make sure the layer fan is running too at 100% for starters. It will also help eliminate the stringing.
Posted: Fri Oct 02, 2015 7:15 pm
by drwho
Thank you for your tips, it was running much too hot and as a result was over extruding. Turned it down to about 195 and it seems to be doing much better. We have moved to the FE PLA, and it seems to be printing great. The front seems to be not sticking but I think we just need to recalibrate some things. Ill post pictures a little later.
