Max Metal Aluminum Bed Mount Including FSR Mounts
ZakRabbit
Post by ZakRabbit »
This is what I came up with for mounting my bed to the Trick Laser Max Metal frame based on geometry provided by Brian. It includes pockets for FSR's. I'm making it out of aluminum, but if you're creative and cut it up, I'm sure it could be printed then glued.
ZAKS BED MOUNT INCLUCING FSR POCKETS.STL
(84.46 KiB) Downloaded 307 times
ZAKS BED MOUNT INCLUCING FSR POCKETS.DXF
(58.82 KiB) Downloaded 289 times
Renha
Re: Max Metal Aluminum Bed Mount Including FSR Mounts
Post by Renha »
Thanks! i'll check it later
EDIT: strange dimensions in STL :)
3D printing is magic!
ZakRabbit
Post by ZakRabbit »
Renha wrote:Thanks! i'll check it later
Sorry, it is in inches. If I can fix anything, please let me know.
bvandiepenbos
Post by bvandiepenbos »
Netfabb can scale inch parts to MM
(simply scales it up 25.4)
probably could do the same in Repetier, Matter Control or whatever slicer you use.
although I think netfabb does a better job re-sizing.
I *ALWAYS* run my parts through netfabb before slicing, to fix any issues and to verify size.
