Hi guys,
I have a piece of PEI on the glass bed. It works wonderfully. I can easily pop prints off after the bed cools by 10C.
I was doing fine calibration and found out something interesting. Calibrating in front of each of the towers the bed is flat by .01mm. The problem is this.
I was doing single layer calibration circles and found that in front of the Z tower closer toward the center, there is a rise or something. Anyway, the spot of about 2x2 inches is higher than the rest of the bed by about 0.15mm. Should I just sand this spot down? What grit do I use to do this? 2000 grit for final finish of the surface after sanding?
It is really annoying to find a high spot on an otherwise flat bed.
Thanks.
Felix
PEI not exactly flat, do I sand it?
Fiddler2070
precisionpete
Re: PEI not exactly flat, do I sand it?
Flip it over and check.
Short answer is yes but lap it onto a flat surface instead of trying to locally remove the bump. You could just make it worse.
Fiddler2070
Can't flip it over. It's already attached to the glass bed.precisionpete wrote:Flip it over and check.
People remove and re-apply the PEI, even after flipping it, quite frequently. Just clean it REALLY goodly like.
*not actually a robot
Fiddler2070
You mean just rip it off the glass? So it just comes off?bot wrote:People remove and re-apply the PEI, even after flipping it, quite frequently. Just clean it REALLY goodly like.
Paging Dr. Hackney...
I've never done it. Use a splash of alcohol to get it started? razor blades could help too.
What exactly did you attach the PEI with.... Was it the strips of adhesive or the sheet of adhesive. I tried to remove the PEI from the sheet of adhesive and stopped due to the concern of breaking something. I understand that if you use the strips of adhesive it does come off.
- Tincho85
I wouldn't mess with the PEI. 1mm thick right?
Why don't you sand the nylon spacers?
They are cheap, and could be easily replaced.
Martín S.
