Hi i'm bernard
Just received and built my rostock max v2
Still tweaking the printer a bit but getting there
thanks for letting me on the forum and hope to learn/contribute to it a lot
thx!
Hi from the Netherlands
- bvandiepenbos
Re: Hi from the Netherlands
Welcome to the Forum
Welcome to the Forum!
If you get a chance it would be great to see some pictures of your printer.
If you have a problem or a question just let us know and someone on the forum
will help you out. Thanks for buying a Rostock Max V2!
- mvansomeren
Welcome from a transplanted Nederlander.
Thx for the warm welcome!
Will post some pics later.
I'm currently considering changing the hotend to one that can handle higher themps and has less problems with XT from colorfabb.
Can anyone recommend a good hotend?
Thx!
Thx!
What problems did you have with XT? I recently printed some Carbon Fiber XT (CF-20) with a stock seeme hotend without problems.
*not actually a robot
Sorry for the late reply,
The hot end doesnt seem to keep to 245 deg, which was the value i set for the temp
Colorfabb suggest to use temps between 240 and 260 deg. and when printing at app. 50 mm/s the extruder clicks suggensting that it cannor extrude fast enough.
So i figured that a diffenrent hot end might have lower push resistance
thx!
thx!
i was just at Keukenhof... pretty cool
[img]https://lh5.googleusercontent.com/-0cAq ... 33_001.jpg[/img]
