I am trying to use the auto calibrate and I get the warning that
Warning Moving Too Low
You cannot move any lower. This position on your bed is too low for the extruder to reach. You need to raise your bed or adjust your limits to allow the extruder to go lower.
I never had an issue before what could have changed? I just installed Matter Control version 1.2.2. I had to do a fresh instal because my older version would not update. This new version also says there is an update but it just hangs retrieving download data.
I had the printer set up pretty good but now I am not sure how to fix this.
Thanks.
						Warning Moving to Low
				Earthbound
Re: Warning Moving to Low
Just guessing, but I suspect the new MC install has a default value that needs to be changed for the height of your printer.
I've been having the same issue as well.  How do we get it lower.  Increasing print height doesn't work.
Same problem, it worked well with the previous version of MatterControl but now I get the same error.
Did anyone ever figure this out? I get it with version 1.4.0
EEPROM>X, Y, Z Max Pos - Increase a mm or two.
Also relevant:
http://www.matterhackers.com/articles/i ... ontrol-1.4
						Also relevant:
I was having this same issue and increasing the Z max length in the matter control EEPROM did the trick. Thanks for the advice.
							V2 max with the HE280 hotend
