Alright, I am sure the fix to this is simple but when I slice something in slic3r, the gcode at the end ensures that the orion effector goes to the top and hits all three endstops, killin the print nicely and easily. When I slice in cura, the effector head dilly dallies around the middle and sometimes smashes right into the printed object, how do I modify the gcode in cura to do what it does in slic3r automatically? I just looked at a gcode cheat sheet and could not make heads or tails of it, here is my default cura end gcode by the way:
;End GCode
M104 S0                     ;extruder heater off
M140 S0                     ;heated bed heater off (if you have it)
G91                                    ;relative positioning
G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way
M84                         ;steppers off
G90                         ;absolute positioning
;{profile_string}
						Cura gcode funkiness
- redoverred
Re: Cura gcode funkiness
The end code should be something more like this (I removed useless stuff):
This is what I use:
G28 ;home everything
M84 ;steppers offCode: Select all
M104 S0 ; turn off temperature
M140 S0 ; turn off bed temperature
M107 ; Turn off fan
G92 E0 ; Reset extruder
G28 ; Home
M84 ; disable motors
; BEGINNING OF PRINT FINISHED TONES
M117 PRINT FINISHED
M120 S6 P10
G4 P40
G4 P40
M120 S6 P10
G4 P40
M120 S6 P10
G4 P40
M120 S6 P10
G4 P40
M120 S6 P10
G4 P40
; END OF PRINT FINISHED TONES-
Issue is likely the G28 X0 Y0 last I checked, repetier didn't do the right thing for homing selected axis. Just change it to a straight G28 with no arguments.
