First print after:
1. Trick laser skate upgrade
2. 24v power supply
3. E3D volcano using .8mm nozzle .65 layer height
4. printinz (ninja plate) print surface
5. Azteeg X5 smoothieboard variant
X5 works great, I had to solder pins for fast decay. 1/32 micro steps is nice, using 626Pilot's(Seeme CNC forum) beta z mapping which makes life much easier.
https://www.youtube.com/watch?v=DZhlfbk ... e=youtu.be
More upgrades to Soultaken
- [email protected]
Max 2
xyz DaVinci 1.0 with custom FW for Repetier-Host
Future plans
NextEngine scanner
Droplite or other SLA
Future plans
NextEngine scanner
Re: More upgrades to Soultaken
Wow, that volcano puts down some massive layers!
The main goal behind the volcano to squirt out parts faster?
- [email protected]
If the part size allows for thicker layers more than twice as fast. .2 layer with a .4 nozzle vs .65 layer with .8 nozzle at the same print speed. Why print a part with high resolution with half the strength when you are going to bolt a motor to it? Printing parts that need to look good put in a smaller nozzle.
Max 2
Future plans
NextEngine scanner
Future plans
NextEngine scanner
Do you print with anything more "exotic"? Have you tried any of the Nylons, Tritan, PET, or anything along those lines? I'd be interested in using a volcano with something like those.
- [email protected]
Only abs so far, I have some bridge that I will try and post results.
Max 2
Future plans
NextEngine scanner
Future plans
NextEngine scanner
