Config file for Repetier firmware builder
The RAMBo board is finally here, and here's a place to talk about it!
Has anyone created a config file for using Repetier's firmware builder on the website? I'd love to play around with V.092 and keep up with the more current revisions.
http://www.repetier.com/firmware/v092/index.html
I'm currently running "stock" Rambo electronics, and would love to have a starting point to jump off of.
briankb
Re: Config file for Repetier firmware builder
Post by briankb »
I second this request.
Nylocke
Post by Nylocke »
I posted one in my build log. You'll need to scroll down a bit http://forum.seemecnc.com/viewtopic.php ... &start=175
Let me know if anything needs changed
Nylocke
Post by Nylocke »
Known working config file. Just rename to configuration.h
Configuration-2.h
(23.98 KiB) Downloaded 630 times
Jrjones
Post by Jrjones »
How do you set the Z height with v0.92.3 ? I swear I saw it briefly in the LCD menu, but can't find it anymore.
I've got it set via the EEPROM but its far easier to adjust it via the LCD.
Jrjones wrote:How do you set the Z height with v0.92.3 ? I swear I saw it briefly in the LCD menu, but can't find it anymore.
Not sure about which exact version I'm running, but on mine it's: click, scroll to advanced settings at the bottom, click, scroll to set z height at the bottom.
So go to the bottom of the menu list, two layers deep, and you'll find it there.
Jrjones
Post by Jrjones »
Ah, I got it.
I had changed the Z_HOME_DIR to 0 because I thought it was making the carriages move up into the limit switches after homing. But it also turns off the Z Calibration menu if its set to zero.
Return to “RAMBo”
