Adding a second layer fan to Orion
deager4
Post by deager4 »
IS there any way to add a second layer fan to the Orion? Just wondering. Thanks.
Re: Adding a second layer fan to Orion
deager4 wrote:IS there any way to add a second layer fan to the Orion? Just wondering. Thanks.
You can print another fan shroud for the layer fan: http://repables.com/r/212/
Click the arrow on the right of download to get just the stl.
You also will need the fan which is here: http://seemecnc.com/collections/parts-a ... blower-fan
guanu
SeeMeCNC Staff
Post by guanu »
here is the current version of the blower shroud...
Guanu
NEW3-Guanu-Blower-Fan-Holder-Shroud.STL
(87.39 KiB) Downloaded 363 times
deager4
Post by deager4 »
Thanks how would I wire the second fan?
deager4 wrote:Thanks how would I wire the second fan?
The second fan is wired in parallel with the first fan.
deager4
Post by deager4 »
Could I in theory wire three of the together without drawing too much current? Thanks.
Post by Mac The Knife »
deager4 wrote:Could I in theory wire three of the together without drawing too much current? Thanks.
Yes you can, I currently run three hooked together in parallel.
I run 3. Mainly for symmetry / even coverage.
Fans require very little power, so you're fine.
Return to “ORION”
