Hotend - do i need to redo my resistors?
Posted: Wed Sep 24, 2014 12:30 pm
by Tropicalsq744
Hi guys,
so I'm about to install my hotend onto the printer but i have this nagging feeling that the RTV was not applied properly. Should i remove the resistors and reapply (with new resistors) ? The sillicone seems to be holding them really tightly
[img]https://lh3.googleusercontent.com/-7mUW ... 235947.jpg[/img]
[img]https://lh6.googleusercontent.com/-Z8wN ... 235953.jpg[/img]
[img]https://lh5.googleusercontent.com/-NZzz ... 000003.jpg[/img]
[img]https://lh6.googleusercontent.com/-IZRC ... 000014.jpg[/img]
thanks again!
Re: Hotend - do i need to redo my resistors?
Posted: Wed Sep 24, 2014 12:54 pm
by Jimustanguitar
The silicone doesn't have to be cosmetically pleasing, it's just there to "glue" the heaters in place and to help transfer that heat. As long as there aren't air-bubbles trapped inside that would expand when heated, use it until you have a reason to rebuild it.
Posted: Thu Sep 25, 2014 2:04 am
by Russ
Kind of looks like mine did. Should be fine if there isn't any air pockets. When I did the initial hot-end heat-up, one resistor let out a smoky belch, but worked ok. I noticed after some prints that the silicone was coming loose on that resistor, and that there was a clear air pocket in it. This time I tried in inject the RTV in there as much as possible and it's been good since.
Posted: Fri Sep 26, 2014 1:43 am
by Tropicalsq744
thanks guys!
i shall try it out first. let's hope it works! 8-)
