Slic3r 0.7.2b Profiles to get you started
Posted: Wed May 23, 2012 7:47 pm
by seemeadmin
Here's some Slic3r profiles to get you going. Keep in mind that I'm no expert...
I usually keep my Slic3r profiles with my STL models, naming them similar to what I'm printing. And even making a nozzle note or filament note.
Good general straight wall:
bushing block_1750fila_050noz.ini
bushing or 90 bar clamp - fairly solid
(1.49 KiB) Downloaded 593 times
Fair Solid:
spool_hub_175mm_Filament_020_nozzle.ini
spool hub settings
(1.49 KiB) Downloaded 517 times
Creature Feature (like yoda):
yoda_1750mm_Filament_020inch_050mm_nozzle.ini
creature settings for Slic3r
(1.49 KiB) Downloaded 591 times
~PartDaddy~
Re: Slic3r 0.7.2b Profiles to get you started
Posted: Wed Jul 25, 2012 4:44 pm
by jbinion
I was reading your .ini files and it says bed is 200x200. Are you using the full area available for the bed? and is the size metric?
Thanks,
jim
Posted: Thu Jul 26, 2012 7:30 am
by johnoly99
Jim, john here. Steve must have left that as the default. I usually have it set to 185*185, and yes that is in mm
