Slic3r 0.7.2b Profiles to get you started
A place to talk about slic3r software (http://slic3r.org)
seemeadmin
Site Admin
Post by seemeadmin »
Here's some Slic3r profiles to get you going. Keep in mind that I'm no expert...
I usually keep my Slic3r profiles with my STL models, naming them similar to what I'm printing. And even making a nozzle note or filament note.
Good general straight wall:
bushing block_1750fila_050noz.ini
bushing or 90 bar clamp - fairly solid
(1.49 KiB) Downloaded 593 times
Fair Solid:
spool_hub_175mm_Filament_020_nozzle.ini
spool hub settings
(1.49 KiB) Downloaded 517 times
Creature Feature (like yoda):
yoda_1750mm_Filament_020inch_050mm_nozzle.ini
creature settings for Slic3r
(1.49 KiB) Downloaded 591 times
~PartDaddy~
jbinion
Re: Slic3r 0.7.2b Profiles to get you started
Post by jbinion »
I was reading your .ini files and it says bed is 200x200. Are you using the full area available for the bed? and is the size metric?
Thanks,
jim
johnoly99
Post by johnoly99 »
Jim, john here. Steve must have left that as the default. I usually have it set to 185*185, and yes that is in mm
Return to “Slic3r”
