Will the Delrin covers on Misumi 2020
A place for the physical connections
mkx
Post by mkx »
Will the delrin covers over the 608zz work with misumi 2020?
Nylocke
Re: Will the Delrin covers on Misumi 2020
Post by Nylocke »
As long as its 1" it should be fine. 30mm may be pushing it, but it could work. 20mm is probably too small, though I am speculating. They were designed for 1" T-slotted aluminum extrusions.
Eric
Post by Eric »
I think the width of the slot opening is more important than the total width of the extrusion for this question.
Misumi 2020 has a 6mm wide slot. So does 2525, which uses the same size slot. 3030 moves up to an 8mm slot.
The slot width on 1 inch extrusion is 0.255", a bit larger than 6mm. 1.5 inch extrusion uses 0.320" slots, which is quite close to 8mm (0.315").
0.236" = 6mm
0.255" = 6.477mm
Measure your bearing cover. What do you think?
Isn't it fun comparing metric and inch standards?
mkx
Post by mkx »
Thanks guys. I haven't purchased the bearings yet, but will do now.
Return to “Nuts and Bolts”
