Brent's DropLit Projector Calibration
What projectors work, how to modify them and how to make them work
brent
Post by brent »
This is a simple calibration method I devised for the DropLit's projector. It is an active calibration, meaning you have to match objects/shapes/text up for an accurate calibration.
Both of the calibration images are 3"x3"x3", fitting the vats of the DropLits. The images are identical except for the black/blue colorings.
[img]https://i.imgur.com/BgjRdN1.png[/img]
*Print out the image above. You can print it to paper or cardstock, just make sure you are printing to the accurate dimensions of the picture (3"^3).
[img]https://i.imgur.com/QXPaaAQ.png[/img]
*Save the image above to your computer
*Take the printed image and put it underneath your vat's surface. You will want to ensure the picture is square with the frame of the droplit.
*Turn on your projector and project the second image (blue) onto the 'vat'
[img]http://i.gyazo.com/36dbad330969991e2efec5b093004de5.gif[/img]
*You will want to match the black squares/text/markings on your 'calibration card' with the blue squares/text/markings being projected. The GIF above depicts an accurate, active calibration.
Once you are matched up, you are finished calibrating.
Circle versions are below. The circle is 3" round. Same method applies as the images are identical for color-matching
Projector Image:
[img]https://i.imgur.com/dRKiuPt.png[/img]
Paper Image:
[img]https://i.imgur.com/OZpO1gP.png[/img]
Re: Brent's DropLit Projector Calibration
The vat is round. :)
brent
Post by brent »
geneb wrote:The vat is round. :)
This goes underneath the Vat. I see your concern and I'll edit the PSD to a round shape for people who want to put it inside the vat, or have the shapes match up.
DavidF
Post by DavidF »
I still say sick one of those sharks with frikin lasers on thier heads to one of the vats and use that for calibration. It would be the coolest acessory there is!
Lost pla castings? see me
brent
Post by brent »
Projector Image:
Paper Image:
JohnStack
Post by JohnStack »
When you say calibration, do you mean Focus?
http://dropc.am/p/KhiI1a
JohnStack wrote:When you say calibration, do you mean Focus?
In addition to focus you need some way to position/adjust the projector, so that the image is aligned correctly (no keystoning) and you know how the resolution corresponds to the size of the object (pixels per inch).
rgthane
Post by rgthane »
Brent,
I just created a pdf set of test 9 patterns that are 3" x 3".
I don't have a projector yet, but I felt these might be useful for both setting the Zoom while open and setting the focus on the printer.
As long as the PDF's aren't rescaled (ie "fit the page"), any of them should work.
Hope this helps the group.
Robin
DropLit Focus Test Patterns 1-9.pdf
(810.3 KiB) Downloaded 768 times
brent
Post by brent »
rgthane wrote:Brent,
Robin
Looks good to me!
Return to “Projectors and How To Mod them”
