New Rostock Max Firmware 091 Blew Up My Printer
inventabuild
Post by inventabuild »
I haven't done updates in a while so somewhere along the way there were changes to the newer firmware that I need to modify for my Rostock Max. What happened today is I uploaded the new Repetier-091-ROSTOCKMAX firmware (from 11 days ago), clicked the home button in Repetiere, then the arms quickly went sideways to cause clicking and slipping before I could prevent damage to my printer...not happy about the $ and downtime this is going to cost me.
Since I don't have time to read through 22 pages in the thread on the V091 update can someone please suggest the troubleshooting steps I need to take so I can use the new firmware with my Rostock Max when I'm able to repair it?
brent
Re: New Rostock Max Firmware 091 Blew Up My Printer
Post by brent »
Send an email to seeme support or call the shop tomorrow, possibly JJJohnson has heard of this occurring before.
inventabuild
Brent, thank you for the suggestion. I phoned support and was told it is possible the motor directions were switched in the Repetier .091 Firmware Upgrade. I just re-loaded the Firmware Upgrade so I could take a video. It looks like more than just the x, y, z motors swapping axes. Here's the video where I was using the Repetier Manual Control window and first I clicked on -X several times, then +X several times.
http://youtu.be/ptGECcjKOHw
Notice the head does not just move backward and forward. It moves back and then swings forward like in a parabola.
How do I fix this?
inventabuild
Thank you Eaglezsoar,
I found and corrected the problem with your post here:
http://forum.seemecnc.com/viewtopic.php ... 0&start=20
I just changed the following true/false values so they matched the values in my previous version of Repetier Firmware which had the axes configured properly for my wiring:
#define INVERT_X_DIR true
#define INVERT_Y_DIR true
#define INVERT_Z_DIR true
#define INVERT_E0_DIR true
inventabuild wrote:Thank you Eaglezsoar,
I'm glad some of my older posts can still be of help.
Happy Printing! :)
