X3 Pro mount for R.MAX v2?
Renha
Post by Renha »
How one could mount it? Has anybody created mounting parts?
3D printing is magic!
Nylocke
Re: X3 Pro mount for R.MAX v2?
Post by Nylocke »
I have one I made for the V2 RAMBo mount, but it doesn't come out once put in place since the X3 Pro is so wide. It's made for laser cutting, I can post it later.
Nylocke
Post by Nylocke »
Attached a DXF and DWG
AzteegX3ProMount.dxf
(131.12 KiB) Downloaded 582 times
AzteegX3ProMount.dwg
(32.84 KiB) Downloaded 547 times
Renha
Post by Renha »
thank you! what width?
Nylocke
Post by Nylocke »
I designed it in mm, its around 161mm in width, unless you're talking about material thickness? In which case its just 1/4", same thickness at the rest of the machine.
Renha
Post by Renha »
I'm sorry (my engrish is wery well), I mean thickness, thank you for so smart answer!
Return to “Azteeg X3 and X3 Pro”
