I have 2 E3D v5s on a v1 Rostock Max. I am using Repetier v91. I am highly successful in printing PLA using a single nozzle using the stock Rostock Max extruder. I am using tricklaser's arms. The extrudes are a variant of my own design.
My first issue is adhesion. Like so many others, i googled my way to find what works and what doesn't. I've tried the following:
- straight glass,
painters tape,
painters tape with elmers,
painters tape with glue sticks,
painters tape with other glues,
straight kapton tape (about 1/2" wide, so you can imagine the number of rows)
Do i need to upgrade my power supply? Is there enough juice to get the two hot ends up to 230 C and the heated bead up to 110 C? Having some issues getting the bed up to temp. Are there low temperature methods to help insure abs first layer adhesion?
2nd question: (tough one)
I cannot for the life of me properly calibrate this thing. It always seems like one nozzle is slightly higher or lower than the other. So the big problem happens is when one nozzle hits the part while traveling and breaking off the part.
My nozzles have springs under the mounts so i can turn and level them out. when I zero (0,0,0) them out they are level at the center of the bed. As I move out one nozzle gets higher or lower than the other. My guess is that the printer radius is off. So i adjust:
Zero the machine (level the heads)
Put a piece of paper underneath to check each head, check to see i'm pulling the same amount.
Go to each tower and adjust the z screws on the carriages to make sure the nozzles are touching.
...so here is where things get fuzzy, if i got one nozzle higher than the other what do I do?
- I can't adjust the nozzle screws because i just zero'd it out at the center, i'd be off if i did that
I can't adjust the z screw because adjusting one doesn't fix the other
I can't adjust the printer radius without knowing my z screws are at least in the right ballpark
How do I work this with 2 nozzles?
Is there an orientation i should have the nozzles in? should they be lined up with an axis?
how long does it take to calibrate? (hours? Days? weeks?) I've been at this for about a week and no more closer than where I started?
Please help.
