Big & Tall Filament Holder Arm for Rostock MAX
Posted: Wed Jun 18, 2014 11:56 pm
I occasionally come across filament spools that have a bigger radius or a taller profile than will easily (if at all) fit on the top-mount filament arms from SeeMeCNC. I also have the wiring harness snaked underneath where the spool holder is, so sometimes even a "normal" sized spool will ride on top of that.
The Big & Tall Filament Holder Arm accommodates spools up to 100m tall (bottom of spool to top of spool) and raises the arm about 20mm higher than stock, so it should hold just about anything you can throw at it without interference.
