TPU Filament
nitewatchman
TPU Filament
Post by nitewatchman »
We are moving towards getting some TPU Filament made to test the feasibility of printing parts that will cross link with Polyurea and Polyurethane. A source test lab has agreed to make some trial material.
What tolerance limits should be applied to the 1.75mm filament. I am thinking that a 1.78-1.80 max to avoid jams in the feed conduit and 1.65 min. The most inportant consideration I think would be consistancy at what ever size is chosen.
Any opinions?
nitewatchman
Batteau62
Re: TPU Filament
Post by Batteau62 »
Having run my Filastruder for a while now. I can hold +/- .02mm. I would definitely shoot for under tolerance rather than over. If you go over too much the spool will be unusable:( Where as an under tolerance can be accounted for in software. Consistency is the key. Good luck with the trials! Let us know the out come.
Generic Default
Re: TPU Filament
Post by Generic Default »
If you need anyone to test it.....
Oh and definitely keep it less than 1.8mm. Trimmer line is 1.65-1.69, very consistent, and it has never once jammed any of my hotends. Undersize is better!
Check out the Tri hotend!
nitewatchman
Re: TPU Filament
Generic Default wrote:If you need anyone to test it.....
Received notice yesterday that the lab has drawn the sample and in their words "It looks really good". Sizewise I don't know what that means although I told them that the important controls were max diameter and consistancy. I think that they have drawn between 2 and 10 Kilos so we will see what it is like. Worst case we will grind it and use in our injection molders.
I will keep you posted.
nitewatchman
teoman
Re: TPU Filament
Post by teoman »
That does sound exciting...
Waiting with impatience.
teoman
Re: TPU Filament
Post by teoman »
Any updates?
jesse
Re: TPU Filament
Post by jesse »
My printer can do right up to 2.0mm. After that the filament gets stuck.
teoman
Re: TPU Filament
Post by teoman »
Generic Default
Re: TPU Filament
That polyurethane would print but it's expensive. The price is the same for a 3mm cord as for a 2mm cord, so using a bigger diameter would be more cost efficient.
Return to “Filament”
