Here is a spread sheet with a partial list of gcodes.
updated
2014.05.03
Gcode cheatsheet
slashthedragon
- Plasticator
Gcode cheatsheet
- gcode.ods
- (22.35 KiB) Downloaded 754 times
Last edited by slashthedragon on Sat May 03, 2014 7:45 am, edited 1 time in total.
Re: Gcode cheatsheet
That file wouldn't open correctly in Excel for some reason.
This is where I look for general reference on specific commands: http://reprap.org/wiki/G-code
What's actually implemented in a firmware is generally documented in the firmware source. In the case of Repetier, that list is in "Repetier.ino" (first tab if using the arduino editor).
Worked for me after repairing...try this
- gcode.xlsx
- (15.63 KiB) Downloaded 824 times
ODS is an open desktop spreadsheet file. Don't expect a Microsoft product to properly operate on a file type they can't vendor-lock you in to.
Also, FYI guys, all the firmware i know of has comments with all the implemented g codes for it, for example, the repetier.ino file for the repetier firmware shows all the gcodes it knows, look there, or for quick reference, here's a link
https://github.com/seemecnc/Repetier-09 ... petier.ino
