Display gcode for showing off?
Lasivian
Post by Lasivian »
Does anyone have some gcode for moving the device through it's limits to show it off?
IE. Friend shows up and says "What's that do?" and you hit Script X and it goes all crazy for a minute then homes again.
I want to use it as much for printing as for getting attention during events.
Christian79
Here ya go…..
Post by Christian79 »
Found this code on Youtube…….
https://www.youtube.com/watch?v=KEH7Ji4a3Ss
In the attached file I have removed the first line of his code which was there to set the steps/mm to 40. That is incorrect for our machine and I bet his as well since he had the feedrate set at F12000.
I also reduced that because I could not bare to watch the MAX run like that, F12000 is WAY TOO fast.
Here is the modified gcode that I have been running on my MAX for over 20 minutes now. It just imitates the motion of a spiral and then repeats.
Enjoy….
motion_demo_F6000.gcode
(2.9 MiB) Downloaded 250 times
