"H-1 Mechanical Assembly Manual"
Here's where you can find the official (and unofficial too) things like assembly instructions etc...
Hey folks, here is the most current version of the H-1 Mechanical Assembly Manual (version 1.01). It has a few edits that folks have sent me. Please use this thread to ask questions, suggest edits, etc.
H-1_Mechancial_Assembly_Manual_1-01.pdf
(15.13 MiB) Downloaded 1752 times
Here is a detailed breakdown of parts used in each step. Please provide feedback if you find differences or errors in this list so I can update it.
H-1 Parts.xls
(40 KiB) Downloaded 831 times
Cheers,
Michael
Dave_Sohlstrom
Re: "H-1 Mechanical Assembly Manual"
Post by Dave_Sohlstrom »
DL worked looks good Michael
Dave Sohlstrom
H-1 Tank
Great, thanks for testing that Dave.
cheers,
Michael
AndGorew
Post by AndGorew »
On page 8 where it says 30318 M3-.05 x 10mm Phillip Pan Head Screw is it really .05 size or is it .5 because .05 is unrealisticly small and nobody caries those from what i have been told.
AndGorew, you are most likely correct. All of the exploded parts diagrams have M3-.05 so those will all have to be changed too.
Interesting, if you search for M3-.05 you will find dozens of pages with this same error, even charts that have M2.5 x .45 then M3 x .05 and back to M3.5 x .6 - mix and match (see Imperial chart).
I'll work with Steve on getting these updated.
thanks,
Michael
Dave_Sohlstrom
3mm course thread has a pitch of .5mm not .05 so it should read M3X.5
Dave Sohlstrom
H-1 Tank
Yes, Steve is going to update all of the diagrams and I'll make the changes and repost as soon as they are done.
cheers,
Michael
update: "H-1 Mechanical Assembly Manual"
I posted an update to the pinned post to include an attachment. It is an Excel spreadsheet with a detailed breakdown of parts used in each step. Please provide feedback if you find differences or errors in this list so I can update it.
regards,
Michael
Extrude3D
Post by Extrude3D »
Just printed all of it out. Jeez :)
-Extrude3D/Brent
jbinion
Post by jbinion »
In the assembly guide it has a "need photo here" for the hot end and thermister wiring, is it posted somewhere?
Not yet but there is some info on wiring the thermistor and resistors in the build threads section. It is pretty straight forward, all the photo is going to do is show how to route the wires so they do not short or interfere.
Regards,
Michael
codenomad
Post by codenomad »
N00b alert. Does this manual cover the H1.1 release? (Just want to be sure before I send to my inkjet printer ;) )
Not yet. I'm waiting for my kit in order to do the manuals.
Cheers,
Michael
johnoly99
Post by johnoly99 »
mhackney, you've got mail (the snail mail kind though, should be getting your "present" soon)
Excellent, thanks. I'll let you know when it arrives.
Chefs,
Michael
Return to “Rostock MAX Official Docs”
