new firmware but the extruder no longer goes
All about the retired H-1.1 3D Printers
MZweifel
Post by MZweifel »
Hello, after i installed the Headbed no longer does my Extruder. Which firmware do you use and how the config files is set with you. Sorry for my bad english. thanks for the help. Marco
Re: new firmware but the extruder no longer goes
Use the Repetier firmware from the download.seemecnc.com website. Gene's assembly manual goes through the setup steps involved (check out the official docs section of this forum).
This is a rambo board, right?
I would also look in Gene's manual to make sure that you're plugging the right steppers into the right ports. There are 2 ports for Z, so you have to skip one connection before you plug in the extruder.
Um, he posted the question in "H-1.1. 3D Printers". Somehow I don't think my manual can help him. :D
MZweifel
Post by MZweifel »
No, is Ramps 1.4 Board, but I look like I'm the flower
arrangement extruder motor to the right place.
I played the test file for RAMPs 1.4 on the board and
everything worked.
In the Config file I have the board set to 33rd.
The extruder was not the hot test. So I have a new extruder
fitted with new cabel and this is not even warm. The firmware
is the new sprinter-master.
Thank you for help.
Marco
Return to “H-1.1 3D Printers”
