Anyone have a clue why my hotend turns off when I run my Nema 17 geared stepper (5.18:1)? It doesn't turn off when I run the straight Nema 17 (1:1).
Is there a setting I need to mess with in the firmware?
Hotend Turns Off in Repetier
inventabuild
inventabuild
Re: Hotend Turns Off in Repetier
I'm starting to think there's a safety shut off on the RAMBO or somewhere.
This is the Kysan Geared Stepper I'm using: http://www.kysanelectronics.com/Product ... ordID=8318
I had to turn the current from 195 down to 135 to keep the motor from getting too hot. Maybe there is another setting I need to adjust as well? I'm running the geared stepper at 478.13 steps / mm (compared to 92.4 for the Nema 1:1).
Do I need to mess w/ #define MICROSTEP_MODES {16,16,16,16,16} or something else besides just the current and steps / mm?
- daftscience
Do you mean that the heater turns off (hot end)? Or that the motors turn off (cold end)? If it's the heater, I would check your thermistor connection. If it get's disconnected then that turns the heater off.
If it's the motor :/ I'm at a loss. Again, maybe check the connectors.
How hot is "too hot?"
inventabuild
Both Nema 1:1 and 5.18:1 are mounted on top of the RMAX and I was swapping out their bowden tubes in the effector to test them both out.
Turns out the bowden tube running from the 5.18:1 was leaning on the hotend wires to exploit a bad connection at the crimping ferrules. The 1:1 bowden tube wasn't leaning on the hotend wires the same way so the bad connection didn't show up.
Weird...
Weird...
The bowden tube knew what it was doing. Time to get a new bowden tube and melt the old one in front of it as a warning to behave.
Lordbinky, that is just plain nasty...but I got a good chuckle out of it.lordbinky wrote:The bowden tube knew what it was doing. Time to get a new bowden tube and melt the old one in front of it as a warning to behave.
*happy thoughts, backing away cautiously*
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
Since 1996
inventabuild
Done, with all the other 3D printer parts watching...
