- What's the positional accuracy?
- Does it need to be vented to the outside, or is there some air filter it can be run through?
- Does it require any consumables other than cutting material?
- Can I print directly over USB, and is it compatible with LinuxCNC?
- Do you plan to offer a rotary attachment for engraving cylinders at some point?
- Are there any accessories, like lenses for different focal lengths?
SeeMeCNC Laser Cutter
Few questions about the cutter.
Re: SeeMeCNC Laser Cutter
You never, EVER run a laser cutter that's not vented to the outside. Ever.
I've seen cutters from other manufacturers that they sell with absurdly expensive ($1,000+) HEPA filters for unvented use. I guess for the money it's cheaper to cut a hole in the wall.
You also have to make sure the immediate outside is unoccupied. Some level of filtration may be required if you don't have enough open space, depending on the kind and quantity of pollution you're generating.geneb wrote:You never, EVER run a laser cutter that's not vented to the outside. Ever.
I vent mine through the wall using a 4" dryer vent. That vents into the "hut" on the back of my shop that houses my air compressor and the dust collector for the ShopBot.
- barry99705
Heh, had a friend try to engrave a moose antler in an epilog laser engraver. Even vented to the outside it stunk up the office! It turned out really well, but they said they'd never do it again.
I get an odor in my shop when cutting acrylic with mine. i shudder to think how bad that burnt antler must have smelled.
Is SeeMe getting out of the laser cutter business? I don't see it in the shop anymore.
