G-Code object placement and print envelope setup
Talk about Cura software here (http://wiki.ultimaker.com/Cura)
I've gave Cura a try today, and I like the code that it creates (especially the Joris feature!). I know everyone says to try it, but I've been hesitant to because I like how integrated Slic3r is in Repetier Host. It was actually the RepRap Magazine review that I finally couldn't ignore. Anyway, it solved some of the issues I was encountering, and I want to start using it all the time now. I still intend to use Repetier Host as my machine control software though; it's a good g-code visualizer too.
When I import a G-Code file into Repetier, is there any way to move the part inside of the build envelope? Cura is designed for machines with X0,Y0 at the bottom left of a square build area, and the Rostock has X0,Y0 in the dead center of a round build area. Because of this, all of my parts are printing in the top right quarter of my bed and I want to move them closer to center and have the ability to place multiple parts in the same print...
Is this possible?
Edit: I found a setting for the Rostock that makes X0,Y0 the center, so that solves half of my question.
foshon
Re: G-Code object placement and print envelope setup
Post by foshon »
Jimustanguitar wrote:I've gave Cura a try today, and I like the code that it creates (especially the Joris feature!). I know everyone says to try it, but I've been hesitant to because I like how integrated Slic3r is in Repetier Host. It was actually the RepRap Magazine review that I finally couldn't ignore. Anyway, it solved some of the issues I was encountering, and I want to start using it all the time now. I still intend to use Repetier Host as my machine control software though; it's a good g-code visualizer too.
Is this possible?
I'm going to go with no, becuase the g-code is what determines placement. RH has no way to alter the g-code (unless you do it manually) once it's created. It does seem to have some pretty cool features though.
http://www.repetier.com/documentation/repetier-host/
Purple = sarcasm
Latest cura has a rostock option that places 0,0 in the middle of the bed.
Return to “Cura”
