So when I initiate the extruder heat up (step before extruding a small amount of filament), everything goes fine, the temp curve reads an increase. But then the temp starts reading a decrease in temp!
Has anyone had this issue? If not, what could it be? faulty wiring? bad thermistor?
* i did add 22 gauge wire to extend the thermistor wire, but it shouldn't be an issue, right?
On a side note, where do you change the z axis distance? I could only find the printer config in repetier.
The issue is that the tip of the extruder is 20.1 mm away from touching the build plate at z0.
I did increase the printer size in the basic printer shape/settings page to 365.1 , because at that measurement the extruder would reach the build plate surface spot on at z0. Is this wrong? I did put the command to go to z0, but it goes back to the "old" z0, which is that 20.1 mm from the build plate. Where extactly do i go to change the z "0" measurement? or is it done through the adjustment screws?
Any info would help.
Odd Issue with extruder temp
rostockmax2013
- Noob
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- Software
- ↳ Orca Slicer
- ↳ SuperSlicer
- ↳ Cura
- ↳ Simplify3D
- ↳ Slic3r
- ↳ KISSlicer
- ↳ Repetier Host
- ↳ OctoPrint
- ↳ Other
- ↳ Sculptris
- ↳ OpenSCAD
- ↳ FreeCAD
- ↳ Blender
- ↳ SolidWorks
- ↳ AutoDesk 123D
- ↳ EMC2/LinuxCNC
- ↳ Skeinforge
- ↳ Mach3 Software
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
