Are the new pulleys worth the upgrade? do they give better control? Or are they just for stripped belt issues?
Bill
Should I get the new pulleys?
Re: Should I get the new pulleys?
They're probably just cheaper, you can't buy 15 tooth plastic pulleys, at that size they have to be all metal, which increases the price.bplemmons wrote:Are the new pulleys worth the upgrade? do they give better control? Or are they just for stripped belt issues?
Bill
The 15 tooth pulleys will be "more accurate" there is a potential for more speed with the 20 tooth pulleys.
That's an interesting point about print resolution...
20 step motors
16th step electronics
Means 320 clicks per rotation...
Using a 2mm toothed belt, the circumference of the 15 tooth gear is 30mm and the 20 tooth is 40mm...
Sooo..... a 15 tooth pulley can accurately position a carriage to .09375mm and a 20 tooth gear to .125mm.
Does this .03125mm matter when you're printing .2mm layers? Could you even detect a difference in the print? Keep in mind that all 3 carriages are moving at the same time to triangulate any given move... My head hurts
20 step motors
Now I have a migraine, I need some Excedrin after reading that.Jimustanguitar wrote:That's an interesting point about print resolution...
20 step motors
20 steps per rotation? Are you sure that's not 200?
- dan
- dan
Holy crap, you're right! Add a decimal place to all of my math.... Um, I mean...... Stupid autocorrect changed all of my µm's into mm'sdbarrans wrote:20 steps per rotation? Are you sure that's not 200?
- dan
