Rostock Max kit change log
Here's where you can find the official (and unofficial too) things like assembly instructions etc...
dbarrans
Post by dbarrans »
I thought I'd start a thread here to document changes to the kits as shipped from SeeMeCNC. It'd be great if they would update this as well. Here are some changes I've seen from newer posts since I got my kit, in no particular order.
* The hot end now has a relief hole into the side of the resistor hole.
* New mounting holes have been added for the RAMBo on the interior partitions of the base.
* Onyx is now included with the kit.
* The design of the nozzle has changed.
* The RAMBo has been updated. I know about the 8-16 change, but what else changed?
* An LCD adapter is now included with the LCD option.
- dan
dbarrans
Re: Rostock Max kit change log
Post by dbarrans »
Injection molded spacers for the belt idler bearings.
- dan
RAMBo was updated to version 1.1 and the list of differences are here on the manufacturer's site: https://ultimachine.com/rambo and here: http://reprap.org/wiki/Rambo
dbarrans
Post by dbarrans »
20-tooth plastic GT2 pulleys have replaced 15-tooth aluminum pulleys.
John told me "Yes, we are now shipping with 20 tooth pulleys. The firmware changes needed are to adjust your steps per mm in configuration.h from 106.666 to 80.000 for X Y and Z axes, and that's all."
- dan
This is also mentioned in the latest doc update I pushed. :)
dbarrans
Post by dbarrans »
I saw John said they're machining the arms now, so they don't need to be sanded.
- dan
johnoly99
Post by johnoly99 »
LCD Controller is included with all kits now
Acrylic is no longer an option, white and black melamine only
The door for the right side has no holes anymore cut in it
608 Bearing covers are now black acetal instead of white (they're purdy'er)
Repetier Firmware now flashed on all kits shipping after 4/23/2013 ( link is https://github.com/seemecnc/RepetierMAX )
Return to “Rostock MAX Official Docs”
