RSMV3.2 extrusion
wellthad
RSMV3.2 extrusion
Post by wellthad »
I have been loving this machine after the upgrade. There're two things I'm still trying to work out though. The first is that the pressure in the bowden tube is lost during retraction causing a little underextrusion at the beginning of some paths. The second is accuracy. It's close but not quite there. On the 0.15 - 0.5 clearance test on thingiverse it fuses both the .2 and .15 in place. Any assistance with this would be highly appreciated.
Re: RSMV3.2 extrusion
What slicer are you using? What are your retract speed & distance set at? What's your nozzle size?
tnx!
