Simplify3D Settings
PhantamaroK
Simplify3D Settings
Post by PhantamaroK »
Would any kind soul be willing to share their Simplify3D settings? At this point I'm throwing darts at the wall with regard to retraction, etc. and would love to use someone else's common settings as a base.
Re: Simplify3D Settings
Try the files in the attached zip. There are profiles for a number of materials & machines.
jwcproductions FFF.zip
(56.09 KiB) Downloaded 605 times
PhantamaroK
geneb wrote: Fri Nov 20, 2020 8:36 am Try the files in the attached zip. There are profiles for a number of materials & machines.
Thank you so much for these files! They're very valuable.
Quick question: are the settings in the Rostock MAX v3 profile the same for the v3.2 upgrade?
No, the v3 uses an 8 bit RAMBo controller and the v3.2 uses the 32 bit Duet controller. It makes them VASTLY different machines because of that.
Return to “RostockMAX v3”
