Print completed but print head did not home?
Culyx
Post by Culyx »
Print completed successfully and I went to check the printer, the print head was still down. So everything was 100% but apparently the print head just did not home back after finishing the print.
[img]https://imgur.com/a/TF8xkJQ[/img]
As you can see there's just an indent at 0,0 where the head stopped, but it didn't rise back to the top of the tower; so things cooled and there's a divet. =P
Using CURA 4.5.1 to slice, anything to check on or is this just a random error?
Re: Print completed but print head did not home?
Check to make sure there's not an M84 command in your end-gcode. M84 turns the steppers off and that can cause the hot end to slowly lower to the bottom of the printer.
Culyx
Post by Culyx »
Wow, that was on point, here's what I see at the end of this gcode:
G1 F3000 X24.604 Y-4.805 E2303.46894
G0 F21000 X24.604 Y-5.512
G1 F3000 X25.202 Y-6.11 E2303.5041
;TIME_ELAPSED:3536.191845
G1 F4800 E2298.5041
M140 S0
M104 S0
M140 S0
G92 E1
G1 E-160 F5000
M203 Z24000
G28
M84
M83 ;relative extrusion mode
M104 S0
;End of Gcode
An M84 line is there, is there something in Cura that i missed that made it do this?
Nope, it's just a like in the end gcode config in Cura. Edit the Cura end-gcode config to remove it. Most of the time the M84 isn't an issue, but for some especially well-tuned machines, it will result in the effector platform slowly sliding to the bottom. The effector platform weight overcomes the static friction of all three individual axes.
Culyx
Post by Culyx »
Do I only need to remove the M84 or is there something else I need to put in it's place for the print head to actually home?
The G28 causes it to home. Just remove the M84.
Return to “Artemis”
