static ip address
felich
static ip address
Post by felich »
I have to go into another room to see what ip address Artemis received.
Is there any way to set a static ip address?
Re: static ip address
If you didn't change the name of the printer in config.g, you can access it via http://artemis.local. If you renamed the printer, make sure there's no spaces in the name - you can access it via http://my_printer_name.local.
dc42
Post by dc42 »
You can set a static IP address using M587 if using a Duet WiFi, or M552 if using Duet Ethernet. But many people use an address reservation on the router instead.
Return to “Artemis”
