Cura 4.5 Profiles
Talk about Cura software here (http://wiki.ultimaker.com/Cura)
PartDaddy
Cura 4.5 Profiles
Post by PartDaddy »
Very happy with the performance of the new version of Cura 4.5 and we've been busy updating new github.com/seemecnc slicing profiles this week.
They fixed the single hotend multiple extruders in this release. Very happy with the performance too.
https://github.com/seemecnc/slicing-profiles
We categorize our slicing profiles by hotend type, then slicer, then slicer version. :ugeek:
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
Re: Cura 4.5 Profiles
\o/
dajay23D
Post by dajay23D »
Thanks! Can you also update the END GCODES? I think something's off. I got a RTP V4 and whenever i use Cura, I get a large retraction when the print ends. It retracts to the point where it separates from the hot end. So i have to manually feed it back close enough where i can run the Load Filament Macros again.
Or i can just copy and paste the Cura Single Extrusion Guide end gcode.
Here's the current gcode in the V4 files.
T0 P0
M18 E1
G91
G1 Z0.3 F10000
G90
G92 E0
G1 E-3 F2000
G92 E0
G1 E-155 F5000 <---- i think that's the culprit! I haven't tried, yet.
G92 E0
M104 S0
M140 S0
M203 Z14000
G28
The line you identified is there to back the filament out of the Y splitter on dual-extrusion machines. You can comment it out by sticking a ";" in front of it.
Dankr
Post by Dankr »
I have a rmax v2 with the e3d v6 hotend. Which would I choose?
Any of the HE280 profiles should work for the E3D v6.
Dankr
Post by Dankr »
Thank you very much! :D
You're welcome!
Return to “Cura”
