Attaching images to posts...
...is actually pretty easy!
When you start a topic, there will be a three-tab box below the editor window:
three tabs.png (2.44 KiB) Viewed 14005 times
Click on the "Attachment" tab and then click on the "Add files" button.
add files.png (11.17 KiB) Viewed 14005 times
This will open a dialog that will allow you to pick your image file or other attachment.
When the upload is completed, you'll see a green checkmark in the Status column at the far right.
In order to add the attachment to your post, click in the editor to put your cursor where you want the attachment to appear, and then click on the "Place inline" button. You can then click the Preview button in order to see what your post will look like with the images/attachments added.
Questions?
Return to “The Lounge”
