M579
CarlJ
M579
Post by CarlJ »
Hello, first off I don't usually post, I am able to find what I need by searching the forum, but not this time.
Calibrating max v2 with duet3dwifi, I make adjustments for my x,y, axis, get them where I want them using the M579 command, save using M500.
They stay till I power down. I did put the M501 at the end of config.g.
Am I using the right commands,or is there a proper sequence of operation.
Machine takes and uses what I put in (M579), changes are made to test piece, just lose it after power off.
Rostock Max V2
Duet3d wifi
fsr's
3dv6 hotend
Thank You
Carl
CarlJ
Re: M579
Post by CarlJ »
:oops: :oops: :oops: :oops: :oops:
Dumb Dumb on my part.
I put the M579 in config.g, but that was it, I didn't put the x, y, z, scaling in.
I assumed that when I entered and saved it would put those figures in.
Its all good now. :D :D
CarlJ
Re: M579
\o/
Return to “Duet”
