Dual extrusion using KISSlicer
This is where you can discuss the RostockMAX v4!
nurbie
Post by nurbie »
RMaxV4 Duet2 WiFi, standard E0 & E1 extruder stepper setup
Is there anything I need to setup in the Duet config/other to let the system know how much to retract/feed as it swaps from one Bowden feed to the other?
I haven't received my PRO(dual enabled) license from KISS yet, so I'm a bit ahead of testing...just being careful/pre-educating?
I've seen Sublime's work, but it's all V3/non Duet from what I recall
Re: Dual extrusion using KISSlicer
I think the tool change scripts that come with the machine do the job, but you can make sure if you email [email protected] - please post their reply here for others. :)
nurbie
Post by nurbie »
please refer to the KISSlicer section:
V4 / Duet2 / KISSlicer / DUAL EXTRUSION Y-bowden FEED and RETRACT?
http://forum.seemecnc.com/viewtopic.php?f=15&t=12782
Where I hope to find 42
nurbie
Post by nurbie »
Wow.
We _really_ need a dev chat with Jonathan @KISSlicer to integrate a SMCNC Rostock Max/other preset group.
This process is a wild search with help from the KISS community being very slim.
Andy/Tim, can you guys contact Jonathan and see if you can get presets going for his next rev. v2?
It's currently in Alpha.
[email protected]
It's very difficult to know what changes I make are doing, or if the G is getting called in the order it is entered.
I've been looking at it and the callouts are close, but the second extruder just never comes online...
I got the CURA generated code to work with the feed/retractions, but CURA just doesn't run on this Mac.
Verifies the loadup and then crash-closes
And yes, I expect that the other post I have out here might garner some more hits over the next week.
Hanging up the dual extruder plans for the weekend!
Return to “RostockMAX v4”
