Printing in mirror image
An affordable delta DIY kit made with high quality electronics/parts/hardware
madox
Post by madox »
[img]https://i.imgur.com/CLHfT8d.jpg[/img]
When I printed the test tower above, the numbers came out mirror imaged. IS this due to a problem building the printer?
At one point, I was told to connect the XY, XY, and Z stepper motor wires to the X,Y, and Z sockets on the motherboard.
I took a guess at which XY was X and which was Y. If this was wrong, would that cause the mirror imaging?
dc42
Re: Printing in mirror image
Post by dc42 »
Swap the X and Y motor connections, also swap the X and Y endstop switch connections assuming the printer homes correctly at present. If you are using software endstop position corrections then you will need to swap those X and Y values too.
Return to “Hacker Series - H2”
