does anybody have a starting Rostock max v2 config.g file
Northspire
Post by Northspire »
I have tried to config my v2 with the kossell file in the firmware but it tries to commit suicide. Anybody have a starting config.g file I will up load the config I am using also.
config.7z
(1.56 KiB) Downloaded 369 times
Rostock V2 Meanwell SP 750-24 Power Supply,710n Nano W/l Router,E3D Chimera Hot-End,713 Maker Effector and Hot-End Mount,Duet 0.8.5,Bondtech QR Extruder,PanelDue W/ 7 Inch T/S,Mini IR Height Sensor,24V Heated Bed With SSR,46 Quart Dry Box.
Re: does anybody have a starting Rostock max v2 config.g file
Post by Xenocrates »
Mine is pretty non-standard, but you can try starting with it.
config.txt
(3.32 KiB) Downloaded 404 times
Northspire
ok I got it working but I can't do a auto config. The printer tries to do one but it's 6 inches above the bed and it grinds the belts so I hit the emergency stop button. Any Ideas? I do have the mini ir sensor.
dc42
Post by dc42 »
Return to “Duet”
